So, check this out... In a (long-) previous log, I had the idea of making use of the SDRAM's DQM inputs to make it possible to connect all 32 bits (four bytes) of the sampled-data to a single byte-wide bus using nothing more than resistors (and, for when the logic-being-analyzed isn't capable of driving the load, 4 74x244's, or similar)...
So, when the sampling occurs, the buffers drive the DQs... The outputs of the buffers are strong-enough to basically treat the resistors as open-circuits... (or, frankly, if the logic-being-analyzed is strong-enough, the buffers are unnecessary... but during sampled-data-read-back it's necessary to remove that logic-being-analyzed from the circuit... so the buffers' output-enables are handy. Nevermind, adding those buffers allows for e.g. making the "logic-analyzer" capable of various different logic-levels... 74AHC's or similar would allow for 5VTTL as well as 3.3VTTL... Others, plausibly in series, could make for 1.8V logic-analysis, etc. And, e.g. it'd be plausible to use 1.8V logic on 16 bits, tied to 3.3V logic on the other 16 bits and determine some intermediate-values for the same measured-signals.).
Now, per a recent log, I think it's possible to handle *more* I/O in a similar manner... Specifically: The Address-lines, which are *directly* fed-back to Data I/O's...
The address lines need a "default" value, as pulled-up/down by resistors, to make this possible.
The *only* "default" value they *need* is that used by the Load-Mode-Register command, so we set those bits accordingly, via pull-up/down resistors, and go on our way. (be sure to check that previous log-entry).
So, note... These resistor (networks) could be replaced with buffers... That'd be the logical way to go about it. But, doing-so, again, results in the necessity for Output-Enable pins for *each* byte. By using resistors we can take advantage of the inherent "output-enable"-nature of the DQM-inputs on the SDRAM.
("Hey! Why not tie the DQM signals *to* output-enable inputs *on* buffers such as the '244? Because DQM is used for BOTH Read AND Write commands... So, we'd *really* need another D-Q latch for *each* of those buffers' output-enable signals. AND FURTHER, using resistors allows for reading AND writing the DQ's (writing being a bit less-necessary in a logic-analyzer sense). )
The use of resistors, instead of logic, basically make for *bidirectional* communication, which would be a bit more difficult with glue-logic.
So... Where we at...?
I have yet to analyze *every single* case... but, having a vague idea of which cases we'll be making use of... I think this should work. Resistors marked "1" are, e.g. 1Kohm... Resistors marked "2" 2Kohm, etc. These aren't *values,* they're *multipliers*... So, maybe, I use 390ohms for the resistors marked "1" and 390*2=780ohms for those marked "2"... you get the idea.
(As the resistance increases, so does the delay in overriding input-capacitances, etc... is that a problem...?)
Anyways, the key, here, is that different *modes* treat these resistor(networks) differently... And, so far, it seems that *each* mode can work with this system.
- Free-Running...
- This is the mode where DQAH/DQAL -> AH/AL. This is *also* the mode when sampling of the logic-analyzer bits will occur (written into the side-kick, plausibly through the buffers enabled by the /DO_SAMPLE input).
- In this case, the "bus" value is of little importance (and should probably be Hi-Z by the "host")
- None of the *connected-through-resistors* bits interfere with each other (right?)
- DQ_AL -> AL
- DQ_AH -> AH
- Input-buffers on Bytes 0-3 go to DQB0-3
- Write to AddrH/AddrL
- DQB0-3 are High-Z (Via DQMB0-3)
- DQMAL/AH (opposite that being written) is active, allowing write to *only* the selected AddressDQ's
- A resistor of value "2" overrides that of value "4"...
- Read from AddrH/AddrL
- DQB0-3 are High-Z
- DQMAL/AH allow read from *only* the selected AddressDQ's
- DQ-values are written to the "bus" via a resistor of value "2", overriding the "default" resistors' of value "4"
- Read from "Side-Kick" DQ's (reading back sampled data)
- DQMB0-3 are set, except for the *selected* byte, so only the *selected* byte outputs
- DQMBAL/AH are set, so the Address DQ's are Hi-Z
- The Selected Byte on the Side-Kick is outputting to the "bus" via resistors of value "1"
- That value is slightly-skewed by the paths through AddrH and AddrL to the pull-up/down resistors... But that *path* is of resistance-value "3", at worst-case, when *both* corresponding AddrL and AddrH bits are tied to either high or low.
There are a few other cases we need (are there?), and I haven't considered *them all* all the way through... But I'm pretty certain that these values are *close*, and darn-near functional.
Here's the thing, VIH-Min = 2V, and VIL-Max = 0.8V... That's *Darn Near* 2/3*V+ and 1/3*V+, respectively. if V+ = 3.0V... A bit of math might need to be done for 3.3V, and a bit more math might need to be done for consideration of the fact that 0.8V != 1V... But Doable...? Plausibly.
And... I've just saved myself not only SIX bidirectional D-Latches, but *also* (and more importantly?) the associated signals that would be necessary to *choose* those D-Latches, and their directions... Don't believe me? Just consider this: Each of those latches would require, at the very least, *both* an Output-Enable (to the bus) and a Direction input... That's already TWELVE new control-signals, avoided by using resistor-networks *and* taking-into-account the latch/direction/output-enable circuitry already built-into the SDRAMs.
Here we go...
pulled-Low due to the Mode that needs to be written to the Mode Register), and the corresponding AddrL bit is pulled-High. And the other case where the AddrH is pulled-Low and the corresponding AddrL bit is Also pulled-Low...
So we have some voltage-dividers...
If we were working with VIH-Min = 2V, VIL-Max=1V, and V+=3V, this'd work... within specs. VIL-Max=0.8V, and I'm *planning* to work with V+=3.3V (or maybe 3.6V)... (Nevermind needing to consider whether the supply voltage might vary slightly). Can the same be accomplished within specs?
wow... trying to wrap my head around this... you are basically building multiplexers? With... priority? based on the resistor values?
Pretty much, yeah... But keep in mind that the SDRAM has, essentially, output-enables built-in (nevermind inbuilt direction-control for Reads/Writes) and those are *definitely* being made-use-of in this scenario.
So, in a sense, this is a bit like connecting a bunch of 74245 bidirectional-buffers to the same 8-bit bus, with the caveat that those buffers' direction and output-enable signals are controlled by some mysterious entity that happens to change them whenever it pleases (and in groups!), rather than allowing *direct* and *immediate* control of each individual output-enable and direction pin.
I'm working on some new diagrams showing the associated I/Os and output-enables as e.g. 74245-style I/Os.
Also doing a bit more verification that it's possible to do this *within* specs... E.G.1: Using VIL-Max = 1V is *probably* functional in most devices, but technically the spec says 0.8V.
E.G.2. VOH isn't going to be exactly 3.0V, and may be dragged down a bit depending on how many outputs it's feeding (is that true for CMOS inputs?), and whether there's a path to ground through the resistors... So, not *certain* those resistor-values are realistic. And, in a case like this, changing one resistor-value affects the *entire* system... (e.g. dropping my "1" resistors to "0.8" while leaving the "2" resistors *at* 2 would fix the VIL-Max problem, but affect VIH-Min.
WEE MATH!
Those "1" "2" and "4"s seem right, in the intuitive-hand-waving sense, but aren't *quite* within specs. And, frankly, this basically will *only* work reliably if that math just happens to work out in our favor. I can recall the basic voltage-divider equation, but now we're talking about numerous voltage-dividers, numerous different scenarios, numerous equations, and numerous unknowns... and, frankly, I don't remember how to do matrix-math, my TI-91's long-gone, and I don't even remember how to *set up* matrix math... And, worse, I never really did wrap my head around math using '<' and '>' (what happens, again, when I multiply both sides by some number? Or when I divide by a variable? Does the sign switch directions?) So we'll see where this goes. I think I can wrap my head around it better if I see some graphs...
Again, I'm pretty sure the "1" "2" and "4" values would *work,* if I ran the thing at 3.0V, but probably not within specs, and maybe not at all if I bumped it up to 3.3V.
So, yeah, maybe saving *numerous* additional OEs and DIRs, but at the cost of some extra thinking and a lot of resistors. (And, in this era, it's entirely plausible that all these resistor-networks could be replaced by a few bidirectional-latches for nearly the same price... And maybe even take less space... There was a previous log where I discovered 'em... I think they were the 74xx16543).
Unquestionably... with bidirectional-latches, this entire system would be within-specs, and therefore unquestionably-(more)-reliable. The question becomes... What can be accomplished by the SDRAM's inherent-features...? It may be a tiny bit slower to wait for the input-capacitances to be overcome by our feed-back resistors... Are those delays going to add up to anything significant...?
