Projects to modify, customize, upgrade, and improve the Monoprice MP Mini Delta 3D Printer.
We came up with the idea for this simple mod because we were unhappy with the User Interface (UI) LCD and control buttons being on the bottom part of the printer.
If you used the printer on a low table or shelf, then you would need to stoop or crouch down to see the screen or operate the controls. Moving the UI panel to the upper part of the printer made it easier to see the display and reach the controls. Here is how we did this mod:
1) Before taking the printer apart, you must print out a copy of the protective cover I designed for the UI. You can find the cover on my Thingiverse page. Here is the link to the object file.
https://www.thingiverse.com/thing:2840660
It will just barely fit on the bed of the MP Mini Delta, so if you have trouble printing it, you may have to delete any skirt or brim settings or anything that prints outside the perimeter of the part, like supports, priming towers, etc. This print has critical dimensions, so you must calibrate your printer or scale the part to accurate size or else it may not fit in the mounting holes properly.
2) Remove the 6 screws holding the top sheet metal cover to the printer, then remove and set aside the cover.
3) Removed the 6 screws holding the bottom sheet metal cover to the printer and set the bottom cover aside.
4) Remove the two screws on the top of the UI panel in front of the build plate, and pull the entire UI panel assembly straight out towards the front of the printer.
5) Disconnect the 4-conductor UI cable from the circuit board on the back of the UI panel, and set the UI panel aside.
6) Remove 4 screws from each of the two lower front plastic tower end caps, then gently pry the two tower end caps up out of the tower extrusions. You don't need to remove them completely, just lift them enough to twist them and expose the panel bracket channels in the extruded aluminum towers.
7) Remove the two screws holding the exposed panel brackets into the channel on each tower. These screws also hold the motor mount brackets to the towers.
8) Slide the two panel brackets out of the tower channels toward the bottom of the printer. You may need to loosen the other screws on the front two motor mount brackets to get enough room to slide the panel brackets past the motor mount brackets.
9) Remove the two screws holding each panel bracket in their channels at the top of the printer behind the panel with the Monoprice Logo printed on it. These screws are hard to reach, but angling the screwdriver a little can help.
10) Remove the 4 screws from each of the front two upper tower end caps, and the center belt tensioning screw holding the belt pulley to the tower end cap. Hold the pulley and belt from below so they don't drop inside the printer. Be careful not to let the belt and pulley flop around because they may jump the belt out of the motor pulley or out of the moving carriage, and this will add more work putting them back where they belong.
11) Pry the two front tower end caps up and move them aside enough to slide the Monoprice logo panel and the attached panel brackets out of the top of the channels.
12) Remove the two screws holding the panel brackets to the bottom of the Monoprice logo panel, and set them aside.
13) Slide the Monoprice logo panel into the channels at the bottom front of the printer.
14) Reinstall the screws that hold the motor mount brackets and panel brackets to the channels in the towers. Don't forget to tighten any of the motor mount screws you previously loosened.
15) Push the bottom tower end caps back into the towers and put the 4 screws back in each end cap.
16) Install the two screws in the top of the Monoprice logo panel.
17) Slide the two UI panel...
I just did this project... not too difficult. just time consuming. Its much better with viability and functions.
Any idea if the MP Mini Delta has any hackable GPIO? A quick google and look at the wiki didn't really turn up anything
