Mechanics, mechanics and again mechanics :)
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 03/18/2016 at 18:230 Comments
Well, the prototype starts to get shape.
The software is doing well too... stay tuned...
Btw, ever needed to mount something on the cheap? Just use some brass-nuts and solder them on cheap FR2 board...
... this is a cheap, easy and fast way of mounting components
... and before you ask, yes I have a CNC 3020 which helped me a little :)
73
