Building a Scale...
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 03/21/2016 at 19:270 Comments
After figuring out the best way of transferring the holes from the load-cell onto some pieces of wood I got my CNC running some time...
Well, I wasn't so sure about the clearance, so I decided not to fully go through the wood...
... but no risk, no fun...
... and the 2nd try went perfectly well :)
Now throwing in some screws and we have a scale!
The plans will come... but I'm sure everone can figure out everthing just by these images...
73
