The first BeeStalker is now connected to the internet!
Check it out: The battery-voltage Vbat is plotted. Things like the GSM cell I'm connected to and stuff like this is of course hidden :)
Repos are up-to-date!
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
