... quite some shorts, but manageable :)
So this is a PI3 with 7(!) USB Ports (4x Front, 1x internal, 2x on top-left headers)!!!
One without CM3....
... and one with CM3 :)
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
One without CM3....
Awesome progress. Your board looks great, hope everything works as expected!
should bei fine... 4 Lasers and mostly copy-paste from app-notes...
Much more interesting will be the power-board...
7xusb+rpi3 well, thats like 5A@5V!
Tomorrow I'll get the parts from digikey...
73
