1Step 1
Choosig components:
I wanted to keep the budget as low as possible while still being able to make it. So all components listed below were obtained from eBay sellers, even the cheapest ones I could find on that website. You are going to need:
- Arduino Pro Mini > US$ 1,99
- MicroSD card Breakout > US$ 2,00
- 2GB (or greater) microSD card > US$ 2,49
- GPS module (uBlox Neo-6M) > US$ 9,95
- 3.7V/600mAh Li-ion Battery (model aircraft ones) > US$ 2,01
- 3.7V to 5V step-up converter > US$ 0,76
2Step 2
Schematic diagram:
The idea is that the Arduino Pro mini manages everything, from GPS readings to SD card writings, because the components needed are only those presented in the imagem below.
Another important detail is the dc-dc boost converter; it is necessary to step-up and adjust the variable voltage from the battery (3.7V and down) to steady 5V that the Arduino Pro Mini and the GPS module requires.
The imagem shows:
- in RED the +5V and Battery voltages
- in BLACK the ground (reference, GND)
- in Green and Yellow the GPS serial communications line
- The other colors are communications and control lines for the micro SD card breakout.
3Step 3
The Arduino code:
The most updated version (if any) of this GPS data logger code can be found in my GitHub page, on this link.
What the code below does is save Latitude, Longitude, date, time and speedto a .csv file called "rundata.csv", every 2 seconds.
Click here to see the code (on GitHub) for the Arduino Pro Mini
4Step 4
Utilization:
Here is a picture of a 21km race I made while carrying my GPS data logger. The track is in red over a satellite view map.
All you have to do is power up the circuit, and it will instantly start logging your GPS data (even befor GPS fix) to the microSD card.
Below I extracted a bit (16 seconds) of the raw data saved to a microSD card.
Lat Long Altitude Speed (km/h)
-26,4750720 -49,0913160 41,9 3,83-26,4750630 -49,0913350 42,1 0,96
-26,4750490 -49,0913500 42,4 6,74
-26,4750440 -49,0913080 39,9 3,63
-26,4750550 -49,0913390 36,9 9,59
-26,4750480 -49,0914190 44 10,91
-26,4750780 -49,0915560 47 15,74
Clovis Fritzen
Ciclo Winstrol has been discussed on this blog page. This blog post is about Dianabol Cistanol. Linda is also described along with others and I can easily visit https://www.resumesservicesreviews.com/zipjob-com-review/ in order to complete the task. Technology is getting better day by day. More innovative things are coming in competition.
