Interdimentional Portal SIM# 3...
I'm just shooting some ideas until I come across that "wow" factor;
Please, any feedback would be appreciated :)
A project log for Interdimensional Portal Gun
A 3D printed portal gun, which projects animated portals.
For now I wanted to just concentrate on generating the animated version on Rick and Morty. You also only have three static images to work with here so the overlapping should be designed to develop apparent motion where there is none.
Ok Daren, I'll work with that platform in mind then :)
