Interdimentional Portal SIM# 3​...
A project log for Interdimensional Portal Gun
A 3D printed portal gun, which projects animated portals.
david-h-haffner-srDavid H Haffner Sr 03/28/2018 at 14:562 Comments
Interdimentional Portal SIM# 3...
I'm just shooting some ideas until I come across that "wow" factor;
Please, any feedback would be appreciated :)
MasterOfNull wrote 03/28/2018 at 15:50 point
For now I wanted to just concentrate on generating the animated version on Rick and Morty. You also only have three static images to work with here so the overlapping should be designed to develop apparent motion where there is none.
David H Haffner Sr wrote 03/28/2018 at 16:12 point
Ok Daren, I'll work with that platform in mind then :)
