Exploded view of gears, image retainer rings, and front bezel/lens carrier.
A project log for Interdimensional Portal Gun
A 3D printed portal gun, which projects animated portals.
Man that is incredible, great mechanical engineering :)
The actual engineering here is pretty simple. Splitting it up so it can all be 3D printed without significant overhangs or bridging is the real trick.
