NPN1 using the 2N222A was triggering flash mode on boot, with some troubleshooting help from member SUF here. I Swapped it out for a pin compatible BS170 N channel mostfet
"the MOSFETs Gate is insulated from the Drain-Source channel,
and not acting like a clamping diode"
Schematic Changes:
