I need to make some improvements like allowing the reaction vessel to spin and maybe finding a vessel that wont crack due to localized heating.
Teflon reaction vessels are generally used for this purpose, I might be able to use high temp epoxy and make a better vessel, but time will tell.
I will be using this method in many of my projects and all that is left to do is to add instructions.
