1Step 1
After some scrounging around I found a cheap axis laser housing with diode and driver board still intact! For me, this is a mirracle as most of the time, I usually disassemble things when I first get them.
![parts I used in this build]()
After I scrounged up the rest of the parts I went to work. To cut the little dice box enclosure I used a drill that was slightly smaller than the laser housing and SLOWELY drilled it from each side until I had a nice smooth hole. Then, I used my hobby knife, flipped on my butane torch, heated up the blade and cut the hole for the switch. This took about 5 minutes time total, including taking the pictures.
![heating knife]()
I failed to take a picture of the holes after I cute them, sorry about that, but you get the idea. The next step was soldering all the connections up. I slipped in the switch and unscrewed the laser housing, they unscrew in the middle to allow access to the driver board, then I screwed it back in, as shown in the picture. I went to solder the switch, in retrospect, it would have been easier to run the lines through the hole, solder it, then snap the switch in… but I did it the hard way. No biggie, I have extremely steady hands and it was like playing that old board game “operation”;)
![operation board game]()
![soldered parts]()
Be sure to heat shrink exposed wires as you are basically just cramming them all into the enclosure after it is done. To keep the battery compartment from rattling around I put a little double stick scotch tape on the bottom. No, I didn’t burn the heat shrink.. that is just soot from the bic lighter I used.
The next step was simply installing batteries, putting it all into the enclosure and adjusting the optics to get a proper beam :D
![laser completed]()
![laser firing]()
I did throw a warning sticker onto the side after, the one I peeled off the axis laser housing to get it apart. To remove those, a blow drier works wonders, just don’t get it too hot or you may damage the diode and internal electronics.
This project is finished!
ThunderSqueak
