Urea Electrolysis
07/09/2016 at 22:25 • 0 commentsUrea electrolysis can occur at .37 volts reducing watts required. A primer video.
Nitrogen Plasma Functionalization vs Ammonia functionalization
03/21/2016 at 23:50 • 0 commentsThere are two strategies for decorating these carbons with Nitrogen groups. If you have a graphene oxide to start with microwaving in simple household ammonia will replace the oxygen groups with nitrogen allowing a much higher concentration around 45% of nitrogen to carbon.
Another far less energy intense strategy is to simply use my nitrogen plasma functionalization route via microwave. Making graphene oxide is a royal pain in the you know what and is not favorable for mass production. The problem being that microwave nitrogen plasma will only yield around 3% to 10% by mass nitrogen functionalities.
So the test obviously has to include these two different compounds. As well as pristine graphene and carbon fiber by itself.
I also have plans to simply use pristine carbon fiber in a solution of suspended/dissolved graphene oxide/nitride. If the coating process can be skipped and no electrolyte used just graphene nitride in solution it would be much easier to prepare and scale much more rapidly.
I am getting all these materials together in preparation for the citizen scientist part of the 2016 HAD prize.
