MyViz 0.2.0 is out !
09/11/2016 at 14:39 • 0 commentsA new version of MyViz is available:
https://www.myviz.io/download/
It is more easy to use than the first one. Our tutorial for Arduino has been modified consequently. We also added 2 new tutorials for ESP8266 (ESP-01 module and NodeMCU):
https://www.myviz.io/tutorials/
And finally, good news: MyViz will be used as control and visualization dashboard creation software by the upcoming robot shield for Arduino, T-Quad:
First release of MyViz !
07/19/2016 at 14:44 • 0 commentsThe first release of MyViz is available for Windows, Linux and Mac OS X, 32 or 64 bits version for each platform !
You can download it here:
https://www.myviz.io/downloadRemember that MyViz can be considered as a desktop version of Freeboard, allowing things that are not possible for a Web application. For example, communicating with the serial port.
So, the very first example shows how to communicate between MyViz and an Arduino Uno:
https://www.myviz.io/communication-with-an-arduino-on-serial-portEnjoy, and don't hesitate to ask if you have any question or problem !
