ttp://www.bunnings.co.nz/arlec-remote-control-power-outlet-3pk_p00286271
Light switch remote, wired into arduino uno from Brenda Wallace on Vimeo.Hooking arlec RC power switches up to modern home automation systems
26631840925_0fa0139ca2_o.jpgArduino Uno controlling the remote.JPEG Image - 3.00 MB - 04/25/2016 at 23:55 |
The switches cause the micro to send the signal, when they are pulled low.
I've hooked up a voltage divider on each GPIO digital pin on the arduino, so about 2.5V appears at the switch, instead of 5.
This worked for one switch (on and off). THe arduino uno is 5V and the remote is 3V - one i connected all 4 (actually 8) switches, the voltage got to high (4V across the gnd return)
I'm going to need to level shift this.
Opened up the remote. desoldered some of the switches. The board in this remote is SHITTY. it desintergrated and the tracks lifted.
A simple pullup/pulldown won't work here - ordered some mosfets from RS components.
== On switch one ==
Decimal: 1786417050 (32Bit) Binary: 01101010011110101000111110011010 Tri-State: not applicable PulseLength: 263 microseconds Protocol: 1
Raw data: 8152,744,256,744,252,744,252,264,208,1280,48,464,60,1420,72,440,368,1020,332,1744,268,732,264,732,264,248,748,736,256,256,744,736,264,248,752,244,752,248,740,768,12,736,12,740,256,740,256,740,256,748,248,264,736,260,740,740,256,744,252,260,736,740,260,256,736,
Decimal: 1786417050 (32Bit) Binary: 01101010011110101000111110011010 Tri-State: not applicable PulseLength: 262 microseconds Protocol: 1
Raw data: 8152,744,260,736,260,736,264,252,744,736,268,244,736,752,244,272,728,264,744,732,264,736,260,736,264,732,264,252,744,736,260,252,748,732,264,252,748,248,748,252,744,736,264,732,264,732,264,740,260,736,260,256,744,252,744,736,260,736,264,252,744,736,264,248,740,
Raw data: 8164,736,264,736,260,736,264,248,748,732,268,248,748,732,264,252,740,260,736,744,260,736,264,732,264,732,264,252,744,736,264,248,748,732,268,248,748,248,752,244,752,732,264,732,264,740,260,736,260,736,264,252,744,252,748,732,264,732,268,248,744,736,264,248,740,
Raw data: 8156,740,256,740,260,736,260,256,744,736,260,252,744,740,260,252,744,252,748,736,260,736,260,744,252,736,264,252,748,732,264,252,748,732,260,256,744,252,744,252,744,736,264,736,260,736,260,740,256,740,260,256,744,252,744,736,260,736,264,252,744,736,260,252,740,
Raw data: 8164,736,264,736,260,736,264,252,744,736,264,248,748,732,264,252,748,248,748,736,260,736,264,736,260,736,260,252,748,732,264,248,748,736,264,248,748,252,748,248,748,732,264,736,260,740,260,736,260,740,260,252,748,252,744,732,264,736,260,252,744,736,264,252,740,
Raw data: 8148,744,256,740,260,740,260,252,744,736,260,256,740,740,256,260,740,256,740,740,256,744,252,748,252,740,260,252,744,736,260,256,740,744,248,268,740,252,744,252,744,736,264,736,260,736,260,744,252,744,256,256,740,260,736,744,252,744,256,260,736,744,256,256,732,
Raw data: 8160,736,264,732,264,732,268,248,740,748,248,264,732,748,248,268,740,256,740,736,264,732,264,736,260,736,264,248,748,732,264,252,748,732,264,252,748,248,748,248,748,732,264,732,268,732,264,736,260,736,264,248,748,252,744,736,260,736,264,248,748,736,264,248,740,
Raw data: 8148,748,252,744,252,744,256,256,732,756,84,432,92,1388,240,272,112,888,92,88,40,1256,244,748,260,740,248,752,248,264,732,748,248,268,728,748,260,252,744,252,748,252,740,740,260,736,260,740,256,736,260,260,260,252,744,736,256,744,256,256,744,736,260,252,736,
Raw data: 8164,736,260,736,260,736,264,248,748,732,264,252,744,736,264,248,748,252,744,736,260,736,260,740,252,740,264,248,748,736,264,248,748,732,264,252,748,248,752,244,748,732,264,736,260,736,264,736,264,732,264,252,744,252,744,736,264,732,264,248,748,732,268,248,740,
== Off switch one ==
Decimal: 1786414998 (32Bit) Binary: 01101010011110101000011110010110 Tri-State: not applicable PulseLength: 262 microseconds Protocol: 1
Raw data: 8152,748,252,740,256,736,264,252,740,744,256,256,740,756,40,476,36,2448,12,960,264,748,52,948,44,464,728,740,260,260,364,1128...
From the remote (works) Decimal: 1786416795 (32Bit) Binary: 01101010011110101000111010011011 Tri-State: not applicable PulseLength: 262 microseconds Protocol: 1 Raw data: 8148,744,252,740,264,732,268,244,744,744,256,256,712,2988,20,756,244,740,272,732,256,748,248,288,44,1424,20,264,728,748,252,260,736,740,260,256,740,260,736,260,736,744,252,748,248,744,252,260,740,736,264,248,752,248,748,732,264,732,264,256,736,744,252,744,244, From my arduino (doesn't work) Decimal: 1786416795 (32Bit) Binary: 01101010011110101000111010011011 Tri-State: not applicable PulseLength: 263 microseconds Protocol: 1 Raw data: 8172,296,776,808,272,800,268,284,784,812,260,288,788,800,272,276,792,284,792,804,268,804,264,812,260,812,264,272,796,808,264,276,796,808,264,276,796,280,792,280,792,804,268,800,272,800,272,276,796,804,268,272,796,276,796,808,264,808,264,276,796,808,264,808,264,
I had a think about going down this path.. I did almost buy the ARLEC device and hook it up to UNO....I went down the path of the ESP8266 with a solid state relay, clearly not as "pretty" as the ARLEC devices but I felt these power units were rather big. I still might buy one and pull the wall units apart, I suspect there is 3-12VDC in it that can be used to drive the ESP8266 board. Did you pull one apart ?
Jake S. Walklate
Meksim
Konstantin D.
Gintaras Valatka
Just bought one of the arlec rc210's yesterday from my local bunnings and tried to listen to the codes using an UNO + 433 Mhz receiver (Seed) but can't pick anything up. Stumbled across the following link this morning - http://www.thebackshed.com/forum/printer_friendly_posts.asp?FID=16&TID=9382
See if you guys have any luck. Am back home later this week and am going to see if i can transfer those codes into arduino code. If you guys do make progress please let me know.
Cheers,
Trevor
