ultra thin custom display ... only 6 gpio for 30 leds
7seg-micro.schsch - 104.90 kB - 06/20/2016 at 11:31 |
7seg-micro.brdbrd - 63.34 kB - 06/20/2016 at 11:31 |
And now how it work ...
https://hackaday.io/project/10280-4-digit-charlieplexed-segment-displayProject replaced with matrix version https://hackaday.io/project/18014-5-alphabets-charlieplexed-matrix-display-22x5
I just received these a few days ago. What is the pinout to drive it?
Have a look at #DYPLED and tell me if the 4014 LED format fits your needs :-)
This is good to know :-) #PICTIL uses 0402 but no charlieplexing to reach higher speed.
Now I wonder how to do charlieplexing in TTL gates :-D
There are so many applications to use your great "pcb sandwich" idea for a display! Are your 0802 LEDs the "side view" type that you just soldered upright? or better yet, can you tell me the manufacturer number of the LED?
I am sorry, I lost source files, I need complete rework this display. You can try reorder this board https://oshpark.com/shared_projects/eL6HGlbh I have not finished arduino code now :(
I ordered that. I'll try it out and let you know about it. Thanks!!!
Do you have board files for this project? I would like to make one for myself
Neat project! Are you willing to share the updated project files with the 3 separate layers?
