Many square tubes have to be cut and drilled for the mechanics of CNC v3.2. To make things easier for me I have build a digital ruler:
I will create a second frame with improved design, soon. With this little helper, I can hopefully save some time.
The second frame is not only needed to make the machine better, but also to write a detailed build instruction. The existing documentation is just a very rough one...
