I will build a small two rooter from sketch. For a prototyping phase I will reuse some of my former projects. Later all electric components will be on a single PCB. The motors will be also directly mounted under this PCB.
Control
- ESP8266
- Handel wifi communication
- AP if no local wifi network available
- host website for controlling and/or sensor data
- Communicate to Atmega via UART.
- if enough time: Use ESP8266 as WIfi UARTbridge to flash the ATmega
- ATmega (probably ATmega 328p like on Arduino Nano/Uno)
- Cotnrolls all motors and sensors.
- Gets commnds from ESP8266 via UART
- Sends sensor data back via UART
- Easy to reprogram (all default functions packed into library)
- UART-USB bridge
- first version will definitely have an CH340 or similar on board. To program both controllers from USB. And for debugging.
- In later versions this will be deleted or not populated with parts.
Power
- single cell Li-Po or LI-Ion battery.
- Battery charging circuit on board (perhaps similar to circuit I used here: #ESP8266 (ESP-07/12) Dev Board )
- Micro USB connector for charging (like modern phones)
- 3.3V regulator for ESP module and sensors.
- Motors will be run direct from the cell voltage or if higher voltage needed via step up converter.
Sensors:
- Air pressure: I did work with Bosch's BMP180 before. So I will use this or a successor.
- Humidity: Maybe SHT21 from Sensirion.
- Temperature: Normally included in Air pressure and Humidity.
- Anti Collision:
- Tact switches for emergency stop
- Ultrasonic: If there is enough time I will built a custom single transducer i2c module.
- Infraed line follower: Basic setup with on LED and two optotransisitors.
Motors / Wheels
- cheap DC gear motors or miniature stepper motors. Some further experimenting is needed here
- If DC Motors I will reuse #DRV8836 Breakout (for prototyping, later only the same IC)
- small LEGO wheels (I did found a nice overview here)
Additional thinks ideas
If there is enough time (or if I like it) I am thinking of some further ides to realize. This is a ongoing lists of ideas:
- Camera support (maybe the gameboy camera) an hosting live image on webpage
- Object recognition via camera. Maybe second camera for distance measuring.
- Sound (Alarm tone or music playback)
- Servo Arm
- Some mechanism to climb or jump up steps.
- on board display (OLED, LCD, seven segment LED or LED Matrix)
Alex
deʃhipu
selena1995
Jan
If you are looking for smaller caster wheels, then Pololu has some nice ones: https://www.pololu.com/product/950
