1Step 1
Unscrew your cable connection
These have a flexible seal which tightens extremely well against anything with a diameter of 3 to 6,5mm:
2Step 2
Solder wires to your 2x2 socket strip and pin header (not shown here). Put heat shrink tubing with inner glue (about 3cm long) over your pin header/cable and shrink it
3Step 3
Insert cable/socket strips into the screw connector. Shove it into it so your soldered pins are not visible anymore. Back:
Front view:
4Step 4
Add glue. It doesn't need to be totally waterproof on this side. Water won't even get to this side of the connection. It' s more or less to fixate the socket header and cable. Let cool/harden
5Step 5
Plug in your pin header connector, add cap and screw together tightly.
Tight to the max!
6Step 6
Drill a 12mm hole into your enclosure, put in the connector, screw on the washer. Done!
