RGB LED animation for Arduino supporting arbitrary matrix sizes
Today I cleaned up some of my code to make it easier to add animations to the library. I haven't tested it yet, so it might all fail miserably. I couldn't find much info about the flashes that fireflies make for this animation. Here is the best info I found: https://legacy.mos.org/fireflywatch/virtual_habitat. It basically says that the color, duration, number of flashes, and interval all vary.
The example installation is close enough to call it complete. The Controls and power supply are in place in a little box I made out of plywood. The lights are installed under the top bunk and the light diffuser is installed. That was a simple rectangle frame I made out of plywood with a sheet stretched over it and stapled upholstery style.
These are the things that I have left to do:
I made a few mistakes along the way:
Diffuser frame with sheet:
LEDs without the diffuser:
When I push the button it just freezes the animation and doesnt cycle through them...not sure what I'm doing wrong.
