1Step 1
Install OS :
Install last version of raspbian on your SD card
2Step 2
Configure both wlan :
configure /etc/network/interface to use wlan0 as DHCP client, and wlan1 as fixed IP address
auto lo wlan0 wlan1 iface lo inet loopback iface wlan0 inet dhcp wpa-ssid "Your Network SSID" wpa-psk "Your Password" iface wlan1 inet static address 192.168.74.1 netmask 255.255.255.0Restart then wlan0 to access internet
sudo ifdown wlan0 sudo ifup wlan0 -
3Step 3
Configure DHCP server :
install isc-dhcp-server :
sudo apt-get install isc-dhcp-serverThen configure isc-dhcp-server
sudo vim /etc/dhcp/dhcpd.confAnd change following linesauthoritative # remove comment # add theses lines subnet 192.168.74.0 netmask 255.255.255.0 { range 192.168.74.10 192.168.74.250; option broadcast-address 192.168.74.255; option routers 192.168.74.1; option domain-name "local"; option domain-name-servers 8.8.8.8, 8.8.4.4; }Then make dhcp server listen to wlan1 :
sudo vim /etc/default/isc-dhcp-serverAnd update that line :
INTERFACES="wlan1"And restart the service
sudo systemctl restart isc-dhcp-server.serviceAnd check service via
sudo systemctl status isc-dhcp-server.service -
4Step 4
configure wlan1 as Access Point :
sudo apt-get install hostapdThen create configuration file
cd /etc/hostapd/ sudo cp /usr/share/doc/hostapd/examples/hostapd.conf.gz . sudo gunzip ./hostapd.conf.gzAnd change following lines :
interace=wlan1 driver=rtl871xdrv # note that driver depends of your wifi dongle bridge=br0 ssid=changeme channel=3 auth_algs=1 macaddr_acl=0 wpa=2 wpa_passphrase=changeme wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMPTo launch it at boot, you need to edit configuration :
vim /etc/default/hostapdAnd change :DAEMON_CONF="/etc/hostapd/hostapd.conf"
Then launch service via :sudo systemctl restart hostapd.service
And check service via :
sudo systemctl status hostapd.service
Note, if you’re using the edimax dongle using driver rtl871xdrv like me, you’ll need to patch hostapd like explained here : https://github.com/pritambaral/hostapd-rtl871xdrv
Here are the steps to make it work with that dongle.
First, get pritambaral patch :
cd /home/pi/ git clone https://github.com/pritambaral/hostapd-rtl871xdrv.gitThen, add sources repository to raspbian :
sudo vim /etc/apt/sources.list
And uncomment line beginning with #deb-src.Refresh list and get hostapd sources.
sudo apt-get update cd /home/pi apt-get source hostapdWe’l also need some dependencies :
apt-get install libnl-dev libssl-devThen apply the patch :
cd wpa-2.3 patch -Np1 -i /home/pi/hostapd-rtl871xdrv/rtl871xdrv.patchAnd add realtek driver to hostapd config
cd hostapd cp defconfig .config echo CONFIG_DRIVER_RTW=y >> .configThen compile hostapd :make
And replace package :
sudo chown root:root hostapd hostapd_cli sudo chmod 755 hostapd hostapd_cli sudo mv hostapd hostapd_cli /usr/sbin
And restart service :
sudo systemctl status hostapd.service -
5Step 5
Redirect traffic from wlan1 to wlan0 :
Execute following lines
sudo sysctl -w net.ipv4.ip_forward=1 sudo iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE sudo iptables -A FORWARD -i wlan0 -o wlan1 -m state --state RELATED,ESTABLISHED -j ACCEPT sudo iptables -A FORWARD -i wlan1 -o wlan0 -j ACCEPT sudo sh -c "iptables-save > /etc/iptables.up.rules"You’ll needto reload iptables rules at boot by adding that script to rc.local :
sudo vim /etc/network/interfaces
and add :up iptables-restore < /etc/iptables.up.rulesAnd edit sysctl to persist ip forwarding :
sudo vim /etc/sysctl.confAnd add :net.ipv4.ip_forward = 1By now, your Raspberry Pi should work as a basic gateway.
6Step 6
Install and configure MITM proxy :
sudo apt-get install python-pip python-dev libffi-dev libssl-dev libxml2-dev libxslt1-dev libjpeg8-dev zlib1g-dev sudo pip install mitmproxyCreate the payload :
cd /home/pi wget https://gist.githubusercontent.com/paulgreg/e3c80ea35c96a62d4bd0/raw/3bf5183fb1c2f1617839ff977ba8045168b60ec2/unicorn.pyChange rules to act as a transparent proxy :
sudo vim /etc/iptables.up.rulesReplace all rules by that :*filter :INPUT ACCEPT [191:79895] :FORWARD ACCEPT [0:0] :OUTPUT ACCEPT [224:45790] -A FORWARD -i wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT -A FORWARD -i wlan1 -o wlan0 -j ACCEPT COMMIT *nat :PREROUTING ACCEPT [10:625] :INPUT ACCEPT [8:480] :OUTPUT ACCEPT [14:833] :POSTROUTING ACCEPT [0:0] -A PREROUTING -i wlan1 -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080 -A PREROUTING -i wlan1 -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8080 -A POSTROUTING -o wlan0 -j MASQUERADE COMMITThen start mitmproxy :
mitmproxy -T --host
You should see traffic passing by.If that’s ok, start mitmdump :
/usr/local/bin/mitmdump -T -s /home/pi/unicorn.pyYou can then connect to any HTTP website and it should add random unicorns on each visited page.
To intercept HTTPS traffic, first visit http://mitm.it from device and install the certificate authority (check first checkbox when importing certificate). After that some HTTPS traffic can be intercepted.
If satisfied, run that at boot
sudo vim /etc/rc.local
And add this line before exit 0 :
/usr/local/bin/mitmdump -T -s /home/pi/unicorn.py & -
7Step 7
Optionnally, you can connect a small TFT screen :
Configure screen as described in project # Retropie with a 2.2" LCD screen.
8Step 8
Optionnally, set a hardware button to turn Pi off :
Solder a button (you can use GPIO 23 on Pi 2) )and, get the script shutdown.py.
Add then an entry in crontab :
sudo crontab -e@reboot sudo python /home/pi/shutdown.py -
9Step 9
Avoid wifi dongle to sleep :
As explained on that blog, edit /etc/modprobe.d/8192cu.conf :
sudo vim /etc/modprobe.d/8192cu.confand add :
# Disable power management options 8192cu rtw_power_mgnt=0 rtw_enusbss=0to avoid wifi dongle to enter sleep mode.
it's not /etc/network/interface, it's /etc/network/interfaces (s in the end)
