sonar_sensor_array_-_hexapod_-_httpswwwhacksterioslimordium.stl
Sensor array. Print .3mm, 15% fill, no supports, 3 horizontal shells, 2 vertical
sla - 79.18 kB - 05/28/2016 at 14:11
Download
tibia_-_hexapod_-_httpswwwhacksterioslimordium.stl
Print .3mm, 70% fill, supports, 3 horizontal shells, 3 vertical shells
sla - 184.07 kB - 05/28/2016 at 14:11
Download
raspberry_pi_3_mount_for_ssc-32u_on_hexapod_-_httpswwwhacksterioslimordium.stl
.3 mm, 15% fill, supports, 3 horizontal shells, 2 vertical shells
sla - 65.71 kB - 05/28/2016 at 14:11
Download
for_printing_-_new_femur_-_hexapod_-_httpswwwhacksterioslimordium.stl
.3 mm, 20% fill, supports, 3 horizontal shells, 3 vertical shells
sla - 114.93 kB - 05/28/2016 at 14:11
Download
coxa_joint_-_hexapod_-_httpswwwhacksterioslimordium.stl
.3 mm, 60% fill, no supports, 3 horizontal shells, 3 vertical shells
sla - 92.95 kB - 05/28/2016 at 14:11
Download
servo_bottom_case_for_mounting_bearing_-_solar_771772_servo_-_hexapod_-_httpswwwhacksterioslimor.stl
.3 mm, 80% fill, supports, 3 horizontal shells, 3 vertical shells
sla - 26.74 kB - 05/28/2016 at 14:11
Download
head_lid_for_3_sonar_-_hexapod_-_httpswwwhacksterioslimordium.stl
.3 mm, 20% fill, no supports, 3 horizontal shells, 3 vertical shells
sla - 49.79 kB - 05/28/2016 at 14:11
Download
