R-Kade zGO
R-Kade zGO + Raspberry Pi Zero + LCD = Portable Gaming System
R-Kade zGO is a portable video gaming system using a Raspberry Pi Zero.
It's a companion or rather bigger brother to my other RPi Zero project: R-Kade Zero
https://hackaday.io/project/9844-r-kade-zero
The pictures are of the prototype made from a R-Kade Zero controller board, RPi Zero, 2.4" LCD module and a laser cut case.
Solenoid wrote 03/18/2016 at 17:00 point
This is basically a copy of your other project: https://hackaday.io/project/9844-r-kade-zero... why not continue it there?
TonyD wrote 03/18/2016 at 22:50 point
Thanks for the comment and support.
I wouldn't call it a copy, more like a derived work. As I say in the introduction, its a bigger brother to R-Kade Zero. The prototype uses the same PCB from R-Kade Zero but the plan is to design a brand new bigger PCB with controls, RPi Zero, LCD module and battery circuit.
Craig Hissett wrote 03/18/2016 at 14:36 point
This is facking brililant mate! I need to get one!
TonyD wrote 03/18/2016 at 22:51 point
Thanks Craig
Craig Hissett wrote 03/19/2016 at 12:20 point
No problem!
I look forward to seeing how this develops; once it has the battery circuit this thing is going to be so versatile.
Is the screen connected via i2c mate? And are you planning on making the battery circuit modular too? It would be great - it can be swapped for bigger, better battery parts when necessary or even removed completely when not being used with the screen and being used with a TV.
