Hackaday.io Hackaday.io
Sign up Log in
Engine Monitor
Real time graphic readout of critical engine performance parameters.
jan-zumwaltJan Zumwalt
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8.5k views
6 comments
59 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 6
  • The 2016 Hackaday Prize
View Gallery
8.5k
6
59
30
Team (2)
  • jan-zumwaltJan Zumwalt
  • swrothertswrothert
Join this project's team
ongoing project
2016HackadayPrize
Related lists
2016 THP: Microchip Parts
Hackaday Prize Entries using Microchip parts
This project is submitted for
  • Get Started: Design Your Concept
This project was created on 03/18/2016 and last updated 10 years ago.
Description
It is desirable to know the performance of combustion engines in order to make wise decisions regarding operating habits, maintenance, and design impact.
This project is designed to create custom software that utilizes off the shelf inexpensive industry standard existing hardware. Standard sensors and a small color LCD or RGB monitor will display critical engine performance values including:
RPM
Accelerometer and compass
Fuel pressure
Fuel flow/consumption
Estimated fuel/range remaining
Combustion mixture
Manifold pressure
Cylinder head temperature
Exhaust gas temperature
Exhaust gas pollution
Oil temperature
Oil pressure
Air temperature & humidity
charging volts & amps
Customizable for 1 to 6 cylinder engines. Estimated cost less than $99.
Project Logs
Collapse
  • Mixture Oxygen Sensor
    Jan Zumwalt • 04/05/2016 at 22:21 • 0 comments
    Price: $4
    Part: M960909
    Type: 4 wire platinum oxygen sensor
    Product Fit: Direct Fit
    Connector Gender: Male
    Hex Size: 7/8 in.
    Mounting Style: Threaded-in
    Thread Size: M18-1.5
    Warranty: 1-year, unlimited-mileage warranty
    Wire Length: 22.75 in.
    http://www.carparts.com/details/Replacement/Oxygen_Sensor/M960909.html?TID=gglpla&origin=pla&gclid=CM2v-_HC-MsCFUiGfgod5NAOHw&redirect=1
  • Accelerometer, compass, air pressure, temperature
    Jan Zumwalt • 04/01/2016 at 07:49 • 0 comments
    $7 - GY-87 10DOF includes accelerometer, compass, air pressure, temperature
    gyro and accelerometer MPU6050 3 axis
    digital compass hmc5883l 3 axis
    pressure and temperature bmp085 1 axis
    interface - i2c bus
    Code I tested for proof of concept https://github.com/richardghirst/PiBits/tree/master/MPU6050-Pi-Demo
    Purchase Source
    http://www.aliexpress.com/item/GY-87-10DOF-Module-MPU6050-HMC5883L-BMP180-GY87-Sensor-Module/1986963611.html?spm=2114.01010208.3.2.mqhaup&ws_ab_test=searchweb201556_0,searchweb201602_1_10036_10035_301_10034_507_10032_10020_2010016_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_9&btsid=6cc51804-d95d-4fd9-8265-85f72fdd3bcf
  • Oil & Fuel Pressure Transducer
    Jan Zumwalt • 04/01/2016 at 07:26 • 0 comments
    Specifications:
    $10 price
    Part #SKU237545
    Working Voltage: 5VDC
    Output Voltage: 0.5-4.5 VDC
    Sensor material: Carbon steel alloy
    Working Current: ≤10 mA
    Cable length: 19cm
    Working Pressure Range: 0-175psi (0-1.2 MPa)
    The Biggest Pressure: 2.4 MPa
    Destroy Pressure: 3.0 MPa
    Working TEMP. Range: 0-85 degree
    Storage Temperature Range: 0-100 degree
    Measuring Error: ±1.5 %FSO
    Temperature Range Error: ±3.5 %FSO
    Response Time: ≤2.0 ms
    Cycle Life: 500,000 pcs
    Stainless steel is durable, sealed waterproof line
    http://www.aliexpress.com/item/Pressure-Transducer-Sensor-Oil-Fuel-for-Gas-Water-Air/32523806518.html?spm=2114.01010208.3.2.DqUaS5&ws_ab_test=searchweb201556_0,searchweb201602_1_10036_10035_301_10034_507_10032_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_9&btsid=ab83ec34-d7a0-4e73-ac47-d5eaf2bef720
  • Outside Temperature & Humidity
    Jan Zumwalt • 04/01/2016 at 07:13 • 0 comments
    $1 - The DHT-11 will provide outside temperature and humidity.
    http://www.aliexpress.com/item/1pcs-DHT11-Digital-Temperature-and-Humidity-Sensor/32246685842.html?spm=2114.01010208.3.2.FZ68t8&ws_ab_test=searchweb201556_0,searchweb201602_1_10036_10035_301_10034_507_10032_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_9&btsid=0e326206-f43b-4cd1-b5ea-df8c0ffdd9c0
  • 7" Data Monitor
    Jan Zumwalt • 03/31/2016 at 23:51 • 0 comments
    $28 - 2ch HD 800 x 480 7 Inch Color TFT LCD Monitor. I have owned one of these in the past and it works very well with micro processors.
    http://www.aliexpress.com/item/DU-NEW-and-High-Quality-HD-800-x-480-7-Inch-Color-TFT-LCD-Car-Rear/32553771346.html?spm=2114.01010208.8.80.HFOw9T
  • 1500F(800C) 1M K temperature probe
    Jan Zumwalt • 03/31/2016 at 09:50 • 0 comments
    Aliexpress has $2-3 K Type Nylon Braided 800C 6mm Screw Thermocouple Temperature Sensor 1M 3.3Ft. The other option was 2M ohm, but the selection was poor.
    Application:
    4 CHT, 4 EGT
    http://www.aliexpress.com/item/Hot-Sale-High-Quality-Stainless-Steel-High-Temperature-0-To-800-Degree-Thermocouple-K-Type-1000mm/32631426082.html?spm=2114.01010208.3.81.BgLA6r&ws_ab_test=searchweb201556_0,searchweb201602_1_10036_10035_301_10034_507_10032_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_9&btsid=eeb69e66-6739-49d5-9b5c-14a00a8f58ad
  • Expanded External Analog IO
    Jan Zumwalt • 03/31/2016 at 09:29 • 0 comments
    Because this project will require considerably more IO ports that any micro-controller can provide, I identified the best IO expansion candidate as the MCP3008. It is a $4 16pin dip ADC with 8ch@10bits over SPI interface. Since SPI can be daisy chained and only requires 4 IO pins, perhaps 2 of them will serve all the analog interface needs.
    Application
    16ch total = 4ch EGT, 4ch cht, 1ch oil pressure, 1ch oil temp, 1ch fuel psi, 1ch fuel gph, 1ch manifold psi, 1ch air temp, 1ch humidty, 1ch air psi
    Code for proof of concept I tested http://www.hertaville.com/interfacing-an-spi-adc-mcp3008-chip-to-the-raspberry-pi-using-c.html
    Resources:
    http://ww1.microchip.com/downloads/en/DeviceDoc/21295d.pdf
    www.microchip.com/wwwproducts/en/en010530
    https://learn.adafruit.com/raspberry-pi-analog-to-digital-converters
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Per Bandsholm wrote 01/18/2018 at 12:03 • point
Hi, did you have overview or hardware ideas for measuring the RPM from the ignition system without damage the embedded electronic ?
Jan Zumwalt wrote 12/16/2017 at 02:48 • point
Here is a project update and I would like to thank everyone for following the Engine Monitor project - I am slooowly getting some winter work accomplished on it. I've been working on the ignition system so it can be started this spring. Pictures will soon follow :)
Jan Zumwalt wrote 06/14/2017 at 00:24 • point
I wanted to thank everyone who is following the Engine Monitor project. I just moved and had placed this project on the back burner this past year. I now have two VW engines that need to be prepared for flying next year and intend to finish this project this fall/winter. I have a wonderful new shop with the space and tools I need :)
Jan Zumwalt wrote 04/05/2016 at 22:19 • point
M960909
 $4 - 4 wire Ox sensor
sebwiers wrote 04/06/2016 at 17:55 • point
Just from what I've heard, I'd suspect that is a narrow band sensor intended for OEM type use, and it won't indicate correctly outside a narrow range near Stoic.  People doing engine tuning need a wide band sensor.  If that IS wideband (or can be made to work decently as such, maybe just indicating "to rich / to lean") then its a great price spec.
sebwiers wrote 04/05/2016 at 21:29 • point
This looks like it would be useful for all the same things an Air–fuel ratio meter would be good for, plus some... at much lower cost.  Can you actually pull that off?  I know the sensors don;t cost much and just put out voltage, so it may be possible.  If so, I'd love to have one, as would tons of guys who try to tune old motorcycles, etc.
A Project of building a working miniature fridge/freezer https://youtu.be/wh7T6XxJqcI https://youtu.be/e0TZrJyWG24
Project Owner Contributor
Miniature Freezer
jung-hoon-leeJung Hoon Lee
You can measure the temperature without any external temperature sensor, for measuring the temperature all you need is only nrf52832.
Temperature measurement without sensors NRF52832
akarshagarwal98akarshagarwal98
DHT11 is a temperature and humidity sensor which operates at voltage 3.3V~5V.
Measure temperature and humidity with Ameba
daphneDaphne
A Bluetooth Low energy temperature and humidity sensor and logger
RTemp
andrej-rolihAndrej Rolih
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Engine Monitor", please tell us the reason.
Send message
Remove Member
