Mixture Oxygen Sensor
04/05/2016 at 22:21 • 0 commentsPrice: $4
Part: M960909
Type: 4 wire platinum oxygen sensor
Product Fit: Direct Fit
Connector Gender: Male
Hex Size: 7/8 in.
Mounting Style: Threaded-in
Thread Size: M18-1.5
Warranty: 1-year, unlimited-mileage warranty
Wire Length: 22.75 in. -
Accelerometer, compass, air pressure, temperature
04/01/2016 at 07:49 • 0 comments$7 - GY-87 10DOF includes accelerometer, compass, air pressure, temperature
gyro and accelerometer MPU6050 3 axis
digital compass hmc5883l 3 axis
pressure and temperature bmp085 1 axis
interface - i2c busCode I tested for proof of concept https://github.com/richardghirst/PiBits/tree/master/MPU6050-Pi-Demo
Purchase Source
Oil & Fuel Pressure Transducer
04/01/2016 at 07:26 • 0 commentsSpecifications:
$10 price
Part #SKU237545
Working Voltage: 5VDC
Output Voltage: 0.5-4.5 VDC
Sensor material: Carbon steel alloy
Working Current: ≤10 mA
Cable length: 19cm
Working Pressure Range: 0-175psi (0-1.2 MPa)
The Biggest Pressure: 2.4 MPa
Destroy Pressure: 3.0 MPa
Working TEMP. Range: 0-85 degree
Storage Temperature Range: 0-100 degree
Measuring Error: ±1.5 %FSO
Temperature Range Error: ±3.5 %FSO
Response Time: ≤2.0 ms
Cycle Life: 500,000 pcs
Stainless steel is durable, sealed waterproof line -
Outside Temperature & Humidity
04/01/2016 at 07:13 • 0 comments$1 - The DHT-11 will provide outside temperature and humidity.
7" Data Monitor
03/31/2016 at 23:51 • 0 comments$28 - 2ch HD 800 x 480 7 Inch Color TFT LCD Monitor. I have owned one of these in the past and it works very well with micro processors.
1500F(800C) 1M K temperature probe
03/31/2016 at 09:50 • 0 commentsAliexpress has $2-3 K Type Nylon Braided 800C 6mm Screw Thermocouple Temperature Sensor 1M 3.3Ft. The other option was 2M ohm, but the selection was poor.
Application:
4 CHT, 4 EGT
Expanded External Analog IO
03/31/2016 at 09:29 • 0 commentsBecause this project will require considerably more IO ports that any micro-controller can provide, I identified the best IO expansion candidate as the MCP3008. It is a $4 16pin dip ADC with 8ch@10bits over SPI interface. Since SPI can be daisy chained and only requires 4 IO pins, perhaps 2 of them will serve all the analog interface needs.
Application
16ch total = 4ch EGT, 4ch cht, 1ch oil pressure, 1ch oil temp, 1ch fuel psi, 1ch fuel gph, 1ch manifold psi, 1ch air temp, 1ch humidty, 1ch air psi
Code for proof of concept I tested http://www.hertaville.com/interfacing-an-spi-adc-mcp3008-chip-to-the-raspberry-pi-using-c.html
Resources:
http://ww1.microchip.com/downloads/en/DeviceDoc/21295d.pdf
www.microchip.com/wwwproducts/en/en010530
https://learn.adafruit.com/raspberry-pi-analog-to-digital-converters
