Specifications:
$10 price
Part #SKU237545
Working Voltage: 5VDC
Output Voltage: 0.5-4.5 VDC
Sensor material: Carbon steel alloy
Working Current: ≤10 mA
Cable length: 19cm
Working Pressure Range: 0-175psi (0-1.2 MPa)
The Biggest Pressure: 2.4 MPa
Destroy Pressure: 3.0 MPa
Working TEMP. Range: 0-85 degree
Storage Temperature Range: 0-100 degree
Measuring Error: ±1.5 %FSO
Temperature Range Error: ±3.5 %FSO
Response Time: ≤2.0 ms
Cycle Life: 500,000 pcs
Stainless steel is durable, sealed waterproof line
