USB breakout board for easy access to all lines and current monitoring
Nice, clean and simple! You may want to consider thicker traces for VCC and GND, there's a lot of space for that. Also, I am not sure if USB high-speed mode will work with signals going through jumpers. Try it with a flash drive if you notice decrease in file transfer speed. I'd be very happy if you shared such measurement with me :-)
Oh interesting point. I didn't think of that. I'll definitely test that and get back with you.
Cool stuff dude. You might also consider using GitHub for your hardware files. Just a suggestion.
Your suggestion is completely right. I should really get the GitHub started…
Yeah I use GitHub for my source files and for hardware. It's really nice actually.
I actually created a dual side USB breakout board as well: https://oshpark.com/shared_projects/xAAVYrYZ
with inspiration from someone else online: https://oshpark.com/shared_projects/u86uYkNq, http://www.techunboxed.com/2013/06/usb.html
Great minds think alike! Lol.
