Catching Up: Safety
05/02/2014 at 20:38 • 0 commentsI am covering safety as a third post to give context, despite the fact that it is the primary concern. A must for starting a project like this is the appropriate standards. This sort of project is done professionally, and is approved by fire departments, assuming codes are met. Many locations seem to use one standard in specific from the National Fire protection Association NFPA 160: Standard for the Use of Flame Effects Before an Audience
This standard goes through a wide variety of aspects which need to be included in a design, and used during operation and site setup. The reason this is the appropriate standard is that this is a flame effect. It is not an explosion, instead a controlled open flame. It is also appropriate because there are operators, but there are also audience. In my case, the wedding attendees, as well as arguably the couple are audience. I will use this as a guiding principle, meeting as much of it as possible. An older version of this document is available as a pdf elsewhere on the web for those who need it. This is a Group III flame effect, though aspects of other classifications also are applicable.
Beyond what is covered in this standard, there are several safety aspects of the electronics which will be discussed in their design.
Catching Up: Research pt 2
05/02/2014 at 20:21 • 0 commentsThere is a lot of material on the web about building a propane poofer. I won't go into a lot of detail about the plumbing aspects, assuming the reader can find this elsewhere. I also leave this to the reader so that this project is not seen as a simple step by step task. Due to the elements involved, a lot of knowledge is required to build and use this safely. Instead, I will only provide an brief overview and notes about specific decisions I made note of.
A propane poofer uses LP(Propane, as is used commonly on outdoor grills and some home heating), evaporated and reduced in pressure through a regulator, and stored in a tank referred to as an accumulator. The purpose is to allow a sizable volume of gaseous propane which can be vented quickly. The LP in the tank is naturally liquid, and can only evaporate so quickly. Attempting to evaporate faster can cause the system to literally freeze up. In electrical terms, the LP tank can be thought of as a battery, and the accumulator can be thought of as a capacitor.(Ironic that capacitors used to be called accumulators?)
The gas in the accumulator is released through a solenoid valve, and is ignited, commonly with an open pilot light.
A variety of parts are involved in this, all of which must be correctly rated for propane in liquid or gas forms. Many materials cannot tolerate propane exposure. Further, it must be a leak free system.
For ignition, I will go with a hot surface igniter. This will prevent the tell-tale pilot from being visible to the general audience prior to it's use.
I really desire a somewhat slow burn, not loud. The intent will be to run at a lower pressure than many others, with maximum flow. Reducing the pressure will reduce the jet like appearance of some examples out there, as well as the roar.
I am working on the theory that creating the slow burn is best done by retarding the mix of oxygen and propane. I was unable to find any resources which discussed how to implement this, only various build descriptions and videos on the web. In the end, I will have to build it, test it, and adjust from there.
Two ideas that I have not seen implemented come to mind to assist in this. The first is to use a laminar flow nozzle. I was unable to find data indicating if this concept works with gas, and would be happy to hear others thoughts. This method only affects the output barrel, so will be postponed until after initial testing to see if it is worth the effort.
The second is to pre-launch unignited propane to allow a larger volume to be in the air just above the cannon for ignition. Doing this requires a second release barrel which is shielded from ignition, and a timing controller which can sequence the two. Though I could not find resources discussing the safety of this, the primary concern I can think of is the general release of propane which is unburned. Testing will explore this, which will be done initially on a slightly windy day, in wide open air to allow quick dissipation of anything unburned. This idea is to be built into the system from the start as it requires additional parts to be ordered at the same time.
Catching up: Research pt 1
05/02/2014 at 19:19 • 0 commentsThis project actually started last fall, so I wanted to start with some entries to bring any interested readers up to speed.
The reason they had asked me is because I created some fireball launchers for an "interactive game"(some might compare aspects to a haunted house. I can share more about that if people are interested) several years ago. At the time, I created air cannon based creamer system. So they knew I was the person to ask, and they wanted something "cool" at the wedding.
First steps were of course research. I was quite familiar with the aircannon creamer systems I did before(still have them), and though they do create a very ideal display, they are too temperamental. The pilot light sometimes goes out, wind will prevent ignition, and sometimes just random luck will cause it to fail. The solution there was to have 3 launchers, and if some didn't go off, it wasn't an issue as long as one did. That system was good because it was quite safe, and inexpensive. Here, I cannot really afford failure, given that it is part of their ceremony. This site is much more wind prone than the site we used the creamer system at.
Web research was done, I talked with a number of members of a pyro community for ideas. Other things that were considered were a "balloon" with flammable(but oxygen deprived) gas, fireworks type systems, classic cremora's, among others. Many of these had reliability or other safety issues.
In the end, the route I decided to go was basing off the relatively simple propane poofer. Research suggested there were a number of things that could be tweaked to cause the display to be more like what was desired than the loud almost flame thrower effects commonly seen at burningman and many fire arts expos.
Next up, design and safety research.
