Python OS is a complete replacement for the default user interface on the Raspberry Pi. It is intended to be used with a touchscreen attached. It includes a suite of apps and a marketplace for downloading more.
It is programmed entirely in Python using Pygame for graphics. A 3D printable case is on the way as well.
Why should you be interested?
This framework provides a simple and efficient way to write responsive touchscreen apps for the Pi. This can be integrated into existing projects or used on its own. The pyos framework provides a wide range of UI components that can be used to build complex applications.
As of v1.2, Python OS supports scaling to any screen size.
Files
pyos6-1.2beta1.zip
First beta of v1.2. Supports screen scaling and includes a new way of computing Component widths.
Very cool project and already 3/4 of the project is done. It remains to make the interface similar to modern mobile OS and more convenient application. Then this shell and applications can be used on anything, on any devices.
What a pity that the project has ceased to develop. I hope someone there who wants to develop and finished it .
