Spent some time trying to figure out how to allow simultaneous keypresses using DigiKeyboard Library.
Both the problem and the solution were right in front of me but took some time until I figure out that the report size of only one keystroke was hardcoded in Digikeyboard.h file.
First step was to find the Digikeyboard.h file:
In Windows it is located in the following folder
c:\Users\username\AppData\Roaming\Arduino15\packages\digistump\hardware\avr\1.6.5\libraries\DigisparkKeyboard\
In Linux the file is on a hidden folder
/home/username/.arduino15/packages/digistump/hardware/avr/1.6.7/libraries/DigisparkKeyboard/
const PROGMEM char usbHidReportDescriptor[USB_CFG_HID_REPORT_DESCRIPTOR_LENGTH] = { /* USB report descriptor */
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x06, // USAGE (Keyboard)
0xa1, 0x01, // COLLECTION (Application)
0x05, 0x07, // USAGE_PAGE (Keyboard)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x75, 0x01, // REPORT_SIZE (1)
0x95, 0x08, // REPORT_COUNT (8)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x06, // REPORT_COUNT (6 simultaneous keystrokes)
0x75, 0x08, // REPORT_SIZE (8)
0x25, 0x65, // LOGICAL_MAXIMUM (101)
0x19, 0x00, // (Reserved (no event indicated))
0x29, 0xE7, // USAGE_MAXIMUM (Right GUI)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0xc0 // END_COLLECTION
The 2nd parameter in the 12th line was changed to 0x06, to allow up to 6 simultaneous key presses.
The Buffer size was also updated to allow up to 6 keys (plus a modifier)
//private: TODO: Make friend?
// maximum 6 keystrokes, defined in HID report
uchar reportBuffer[7]; // buffer for HID reports [ 1 modifier byte + (len-1) key strokes]
using Print::write;
This is old AF and i just made an account to say thank you. it`s 4AM........ty
