http://www.gizmag.com/the-archimedes-liam-f1-urban-wind-turbine/32263/
A recent development in wind turbines.
A recent development in water impellers.
https://en.wikipedia.org/wiki/Archimedes'_screw
The Archimedes screw, not a golden ratio but can be adapted as such.
http://www.google.ch/patents/US6702552
A ship impeller using the golden ratio.
Victor Shauberger inspired implosion propeller. Yes I know psuedoscience.. deal with it.
Egyptian impeller? You decide on that one guy.
I will turn this on it's head and attempt to use it to produce a low pressure zone over a wing and to provide propulsion.
This documentation describes Open Hardware and is licensed under the
CERN OHL v. 1.2.
You may redistribute and modify this documentation under the terms of the
CERN OHL v.1.2. (http://ohwr.org/cernohl). This documentation is distributed
WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF
MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A
PARTICULAR PURPOSE. Please see the CERN OHL v.1.2 for applicable
conditions
MECHANICUS
Anteneh Gashaw
Bart.remans
Water is an incompressible fluid (at our scales). Air is compressible.
But I think an even more striking difference is the scale of energy : a corkscrew pump that lifts water is around a few hundreds or thousands of Reynolds, while a VTOL vehicle is tens of millions Reynolds with extremely complex interactions.
I apologise in advance if knowledge sounds like arrogance.
