VW-101 Linear power supply
02/14/2018 at 19:10 • 0 commentsI've ordered and I'm waiting for the first run of prototype boards for the VW-101 power module. This is a 3.5 amp three rail linear supply with a maximum 1.5 amp on each channel (total is still 3.5 amp).
This is a pretty straightforward design using a center tap 28V transformer, 4A bridge rectifier, some bypass and smoothing caps, and three L79C series regulators.
No board layout yet. I want to do a cursory inspection when the prototypes arrive to make sure there are no major mistakes. When it's been verified I'll post gerbers and kicad files.
Links and useful information
03/23/2016 at 18:25 • 0 commentsLinks to useful information, ideas, etc.
Aluminum sheet (20"x6"x0.0625") $33.28 from Tri-State Aluminum (937)454-0191 next day pickup
Links & Kinks powder coat (Fairborn) about $25-$30 (937)754-0929
3U (5.25") high
1.5" HU (18" wide for 12 HU) modules usually 1HU, 2HU, or 3HU
Possible regulator for power supply. http://cds.linear.com/docs/en/datasheet/8471fd.pdf
Adjustable 3A buck supply $6.95 http://www.herdware.com/shop/power-supply/switching-power-supply/
+/-15V from 12V http://www.ti.com/tool/PMP10090
http://www.taydaelectronics.com/ MTA connectors
