The project is divided in four main parts :
- Power supply + Amplifier : Managing high power tests
- Analyzer : Managing low power and high power tests
- Rack : Standardize this tool for classic chassis
- Software : Analyze results through sound card
A/ THE RACK
19" rack is chosen as standard in order to put it in a basic amp stage. My choice turns to MDF wood to build the chassis as it is easy to work on and it will break any ground loop as we will not use the ground cable in order to not create extraneous noise in the system.
The main chassis is MDF 18mm, front and back plates are 5mm plywood and top plate will be aluminium in order to mount a fan on.
I chose to put all connection except power plug on the front plate to be easier in connection
B/ Analyzer
C/ Power Amplifier
D/ Software
Krzysztof Wrzalka
Yonghan
Jake
jerpelea
Hi!
I remember myself measuring effective cone mass by attaching a known weight to the cone and measuring shift in resonant frequency.
But I wonder, what parameters do you want to measure? Frequency response? THD? motor strength? sensitivity? efficiency?
