1Step 1
Download gerber files from the zip file included in the project documents and send to your local fab lab to print.
2Step 2
Order components in component list.
3Step 3
Solder components (I used a cheap hot air station)
4Step 4
If desired, solder pin headers to the breakout pins to allow for future development
5Step 5
Compile and upload the code to sensor and receiver
6Step 6
Insert CR2032 batteries into each board. For additional sensors, change the sensorID variable.
7Step 7
Attach sensors to whatever you wish to monitor. Adjust the potentiometer until the sensor is not triggered by background vibrations.
