Hackaday.io Hackaday.io
Sign up Log in
Wireless Rocket Motor Test
Wireless rocket motor test , software pc delphi borland 7 , software pic , mplabx compiler xc8 ,
ramiroselimanramiroseliman
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
430 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
  • The 2016 Hackaday Prize
View Gallery
4
430
3
Team (1)
  • ramiroselimanramiroseliman
Join this project's team
  • Banco de prueba
completed project
hardware
Rockets pic MPLABX xc8 delphi 2016HackadayPrize apc230
Related lists
2016 THP: Microchip Parts
Hackaday Prize Entries using Microchip parts
This project is submitted for
  • Hackaday.com Tip Line
  • Get Started: Design Your Concept
This project was created on 03/27/2016 and last updated 10 years ago.
Description
Details
Files
BancoCoheteria.exe
Software delphi borland 7
x-msdownload - 873.50 kB - 03/27/2016 at 15:43
Download
Components
  • 2 × Apc 230
  • 1 × pic16f628 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × load cell force 250 kg
  • 1 × hx711
Log In/Sign up to comment
Sign up with Github
OR
ramiroseliman wrote 03/28/2016 at 21:06 • point
Where is the jumper ?? , this is in the datasheets from hx711??
ramiroseliman wrote 03/28/2016 at 20:54 • point
Hi , thanks , your projets looks very goods too , about x711 , yes 10 hz from the hx711 , is work very good , the apc230 is great too
J. M. Hopkins wrote 03/28/2016 at 21:00 • point
Were you not able to get it to 80Hz? My hx711 I had to change a solder bridge to makes 80Hz from default 10Hz
J. M. Hopkins wrote 03/28/2016 at 20:51 • point
Looks very good! Are you only getting the 10Hz from the hx711?
I am the co-founder of the Canadian startup Tyto Robotics Inc.
Project Owner Contributor
Co-founder of Tyto Robotics Inc.
dominic-robillardDominic Robillard
Cheap 3d printed hi torque robot actuator with electronics
Hi torque 3d printed cheap robot actuator
pavel-gPavel G.
Measure stepper motor torque
Nema17 torque after dissasembly
thomasThomas
DIY DCMotor smallest Steppermotor with Driver and Servofunction in one package
XMoto DC as Servomotor
frank-herrmannFrank Herrmann
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Wireless Rocket Motor Test ", please tell us the reason.
Send message
Remove Member
