Hackaday.io Hackaday.io
Sign up Log in
Wireless Rocket Motor Test
Wireless rocket motor test , software pc delphi borland 7 , software pic , mplabx compiler xc8 ,
ramiroselimanramiroseliman
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
430 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
  • The 2016 Hackaday Prize
View Gallery
4
430
3
Team (1)
  • ramiroselimanramiroseliman
Join this project's team
  • Banco de prueba
completed project
hardware
Rockets pic MPLABX xc8 delphi 2016HackadayPrize apc230
Related lists
2016 THP: Microchip Parts
Hackaday Prize Entries using Microchip parts
This project is submitted for
  • Hackaday.com Tip Line
  • Get Started: Design Your Concept
This project was created on 03/27/2016 and last updated 10 years ago.
Description
Details
Files
BancoCoheteria.exe
Software delphi borland 7
x-msdownload - 873.50 kB - 03/27/2016 at 15:43
Download
Components
  • 2 × Apc 230
  • 1 × pic16f628 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × load cell force 250 kg
  • 1 × hx711
Log In/Sign up to comment
Sign up with Github
OR
ramiroseliman wrote 03/28/2016 at 21:06 • point
Where is the jumper ?? , this is in the datasheets from hx711??
ramiroseliman wrote 03/28/2016 at 20:54 • point
Hi , thanks , your projets looks very goods too , about x711 , yes 10 hz from the hx711 , is work very good , the apc230 is great too
J. M. Hopkins wrote 03/28/2016 at 21:00 • point
Were you not able to get it to 80Hz? My hx711 I had to change a solder bridge to makes 80Hz from default 10Hz
J. M. Hopkins wrote 03/28/2016 at 20:51 • point
Looks very good! Are you only getting the 10Hz from the hx711?
Cheap 3d printed hi torque robot actuator with electronics
Project Owner Contributor
Hi torque 3d printed cheap robot actuator
pavel-gPavel G.
Measure stepper motor torque
Nema17 torque after dissasembly
thomasThomas
The purpose of my project is to build a system for tracking satellites in orbit.
Build a System for Tracking Satellites in orbit
mark-liuMark Liu
DIY DCMotor smallest Steppermotor with Driver and Servofunction in one package
XMoto DC as Servomotor
frank-herrmannFrank Herrmann
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Wireless Rocket Motor Test ", please tell us the reason.
Send message
Remove Member
