Using the assembler I wrote in Python, I generated some hex code to store in the synthesized ROM on the FPGA. I also added a clock divider to slow the system clock from 50MHz down to 25Hz. This results in about a half second period between increments of the output vector.
Assembler Code:
lw r4, 176(r0) //value to count to should be stored at this address lw r3, 177(r0) //increment value should be stored at this address sub r2, r4, r1 bez r2, 8 sw r1, 252(r0) bez r0, -8 add r1, r1, r3 sll r0, r0, r0 bez r0, -2
Hex Code:
0 => x"84b0", 1 => x"83b1", 2 => x"2142", 3 => x"5008", 4 => x"c1fc", 5 => x"40f8", 6 => x"0b21", 7 => x"0000", 8 => x"40fe"
Congratulations !
Thanks. That was probably the most excited I've ever been to see blinking leds :-)
I understand ! been there too ;-)
