Hi!
I am getting questions about Boxes.py on Windows I can't really answer - both as private message or as GitHub tickets. I personally have not used Windows for anything else than occasionally using a Desktop program (like the control software for our laser cutter) in over a decade. So I really have no clue.
Has anyone been able to run Boxes.py on their Windows machine and is able to share the steps needed preferably including links to the libraries and tools required. Are there any changes that would make installing it easier?
Has any one been able to make the Inkscape plugins work on Windows?
Any feed back that help improving the (very thin) install documentation or the installation itself is welcome!
Update:
Finally we have step by step instructions with screen shots for Windows 10 (64 bit). Many thanks to Martin Müller!
I just tried to get this working a few days ago in win10. I got it to build but it still doesn't run. I'll try to remember all I can.
I was just following the instructions at http://florianfesti.github.io/boxes/html/install.html and googling any issues.
Getting Cairo installed was kinda tricky (I am a python noob). I just needed to install the GTK Runtime.
At some point I started needing to run cmd.exe "As Administrator". I had ended up copying some exe files around (in program files) to get the c++ compiler working, I think that caused an issue with the permissions.
After this the main problem was that the scripts have no extension. Windows can't execute no-extension files (there are a few ways to make it do that with regedit, none worked). I renamed boxes2inkscape to boxes2inkscape.py and modified one line in setup.py accordingly. build/install with setup.py worked after this.
This is where I got stuck. I renamed scripts/boxes and scripts/boxesserver to have the .py extension but I'm not familiar enough with python/your code to change all the usages.
If I run 'python boxes' in cmd from the scripts folder, it runs with no errors. I don't really understand the cmdline version, do you have example parameters that I can try?
Boxesserver throws an error when I try to generate a box:
Traceback (most recent call last):
File "C:\Users\n\AppData\Local\Programs\Python\Python36-32\lib\wsgiref\handlers.py", line 137, in run
self.result = application(self.environ, self.start_response)
File "boxesserver", line 384, in serve
os.remove(box.output)
PermissionError: [WinError 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\n\\AppData\\Local\\Temp\\tmpxjri92p1'
if I try to delete that file, windows says it is being used by python.exe. After I close the boxesserver terminal I can delete it, so it's not another instance of python. Run as Administrator doesn't fix it.
Thanks for all the good work! It would be really cool to get this working on windows. I am willing to test any changes, and if we get this fixed I can do a clean install in a VM and contribute to docs/instructions.
Ok, the permission error is probably caused by not closing the file early enough. Windows is a bit more picky about this than proper OSs. I'll look into this. Thanks for your report!
just sent a PR for that one. Boxesserver is now working.
Sill can't get the inkscape extensions working. I copied the boxes file to my extensions folder and I can generate boxes from the terminal in that folder. I can't find any errors from inkscape. Inkscape doesn't print anything to the terminal. My extension-errors.log file is as follows:
Extension "Dia Input" failed to load because a dependency was not met.
Dependency:
type: executable
string: dia
description: In order to import Dia files, Dia itself must be installed. You can get Dia at http://live.gnome.org/Dia
Extension "DXF Output" failed to load because a dependency was not met.
Dependency:
type: executable
string: pstoedit
description: pstoedit must be installed to run; see http://www.pstoedit.net/pstoedit
Extension "EPS Input" failed to load because a dependency was not met.
Dependency:
type: executable
string: ps2pdf
Extension "LaTeX" failed to load because a dependency was not met.
Dependency:
type: executable
string: latex
Dependency:
type: executable
string: dvips
Dependency:
type: executable
string: pstoedit
Extension "XFIG Input" failed to load because a dependency was not met.
Dependency:
type: executable
string: fig2dev
Extension "GIMP XCF" failed to load because a dependency was not met.
Dependency:
type: executable
string: gimp
Extension "PostScript Input" failed to load because a dependency was not met.
Dependency:
type: executable
string: ps2pdf
Extension "Sketch Input" failed to load because a dependency was not met.
Dependency:
type: executable
string: skconvert
Ok, I'll take this as a "no".
Anyone willing to give it a try? I may be able to offer a custom generator in return (depending on how complicated your wishes are).
