Breadboarding on scrap PLA
A project log for Hacks and tricks
a bunch of small things I want to share, mostly tool related
deepsoicDeepSOIC • 03/30/2016 at 23:44•0 Comments
A gentle push on the component with soldering iron - and it sinks into PLA, sticking to it. Larger components can be fixed with superglue (multiturn trimpot, for example). Then I can wire them up with thin wire. And bingo, a small board made out of nothing!
This is a current regulating circuit based on LM317, with fine current adjustment. LED lights up if dropout is above 2.5 V, which is enough for LM317 to regulate properly.
