terminals for wires
A project log for Hacks and tricks
a bunch of small things I want to share, mostly tool related
deepsoicDeepSOIC • 03/31/2016 at 13:44•0 Comments
Soldering for quickly making connections between random things is often too messy. Yet, having connectors everywhere is not possible. So, I often put wire-wrap pins onto some electronic modules.
The trick here is to put a blob of solder at the end of the pin. Thanks to that blob, the wire wrapped around the pin will not slip off easily.
