Updated SnackClock for 2021!
02/25/2021 at 00:41 • 0 commentsWe revisited this project this year to dispense high fat diet over a 24 hour cycle, and decided to make the design more reliable. Where we used to just push the pellet disk onto the clock mechanism and hope friction held it together, we now are using the brass threaded nut to hold everything together securely. We are also printing the disk in two parts, with an internal hexoganol cog that can get clamped down onto the clock movement. STLs in the files area, here are some photos of the new parts:
And two of them assembled, these were set up with the high fat diet (blue stuff) in the first compartment and left overnight. After 24 hours they dropped it out of the dispensing gap.
Multi-day snackclock!
06/27/2018 at 14:53 • 0 commentsWe purchased some clock movements that are programmed to move in a 4 day cycle for long term diet delivery. I'll update how they work but so far they look good! We purchased them here:
https://www.tindie.com/products/nsayer/crazy-clock/
See it in action!
Paper using SnackClock accepted at Obesity
04/17/2018 at 18:30 • 0 commentsWe used the SnackClock for an experiment in a paper that was just accepted to the journal Obesity. Download here.
SnackClock is live!
03/26/2018 at 13:23 • 0 commentsJust wrote up a short description of the SnackClock mechanism. We have used this in our lab to control feeding behavior. We recently had a paper accepted in the journal "Obesity" describing an experiment using this clock. I'll post the link here when it is published.
