I have done a lot of work since the last log entry. The 16 channel PCA 9685 PWM chip is now supported. New functionality includes servo motor minimum, neutral, and maximum. Also added are LED blink, pulse, pulsate, on and off. The pulsate function allows you to edit attack, sustain, release and interval times, much like creating a sound envelope.
Finally, fixed some annoying bugs, most notably that when a board becomes unmounted the name of the board blanks out in the macro and event trigger editors. You can now edit macros and event triggers even with unmounted boards. The names of unmounted boards will show up red in these editors.
