Rasberry PI 3 Wifi Access Point using Wifi Access
I just wanted to see if I could figure it out, wasn't too difficult. Also used a hidden network, will do a regular one later on.
Got kind of lucky with the wifi adapter. Didnt really do much research other than search for a wifi raspberry pi adapter on amazon and check the reviews. After looking into this a bit seems there are some that don't work or require some extra steps.
new wifi-wifi.txt
plain - 2.56 kB - 12/19/2016 at 02:55
Download
Raspberry Pi 3 Wifi Access Point using Wifi Access.txt
plain - 4.46 kB - 04/03/2016 at 00:51
Download
View all 7 components
  • 1
    Step 1
    Check the attached files for the how to's. Since I found two ways, it's easier just to pic the text file for the style you want.
View all instructions
Rich text editor
FaddedAMV wrote 04/01/2016 at 07:24 point
Next is the TOR!
