11Mount the motor
Snap the motor into the clip in the front, and secure with 2 screws. Don't tighten them up just yet!
Flip the front over and place the pellet disk on the stepper motor. Center it and then tighten the motor screws. It's important that the disk it can spin freely without rubbing on the sides.
12Attach the housing
Slide the housing onto the front, taking care not to pinch any wires or damage electronics. Take especial care with the screen. There are four "snap fit" connections in each corner that will secure the two parts together when aligned correctly.
13Screw on the hopper
Take care that the hopper "feet" end up aligned correctly:
14Slide in the SD door
15Secure the switch and battery
Route the wiring to neatly secure the switch and battery in their holding clips.
16Slide on the back cover and lid and you're done!
Open the back cover and turn FED on and off to confirm that everything is working.
