Project Goals
03/26/2018 at 20:26 • 0 commentsAlways state your goals!
1. Wearable Bass unit for portable use with smartphone audio player2. Compact, Modular design
3. "Tactile" bass frequencies (20-50Hz)
3. Drop-in mounting to hiking water carrier backpack
4. Rechargeable battery for a couple of hours use
5. 3.5mm standard audio jack connection
Possibility to add bluetooth connection later.
Resonater material
03/26/2018 at 20:17 • 0 commentsI'm still puzzling over the resonator material.
The speaker/exciter needs to mount to something dense but very light that will propagate the low frequencies, but that I can easily shape to fit.
I'm thinking something like a thick yoga mat maybe...
Initial Planning
03/26/2018 at 19:21 • 0 commentsDecided that the actual backpack part would be easy - a regular hikers water carrier will be the 'case' of choice:
It already has a pocket which will be about the right size and will hold the unit close to the wearer's back.
I also have a redundant PC speaker set with subwoofer which will form the basic electronics.
Still need to arrange a suitable battery for this.
I plan to test with the original speaker (although it's only a cheapie) as a POC. Researching around the Dayton Audio Bass Exciter looks like it will operate down the the frequency range required (sub 50Hz), so I will source one of these eventually.
