1Step 1
See the GitHub wiki for more detailed instructions.
Step 1: Cut out the test cut panel
2Step 2
Step 2: Find the optimal magnet hole size
3Step 3
Step 3: Find the optimal tab width
4Step 4
Step 4: Edit/change magnet holes in local copy
5Step 5
Step 5: Edit/change tab slots in local copy
6Step 6
Step 6: Lasercut, remove paper backing
7Step 7
Step 7: Press-fit magnets
8Step 8
Step 8: Press-fit pieces
9Step 9
Step 9: Thread and install screws
10Step 10
Repeat as needed!
Peter Walsh
