The Design Specs
05/07/2014 at 20:37 • 0 commentsThe design specs for this project are as follows:
*Needs to produce at least these three waves: sine, square, and triangle wave forms. saw tooth and pulse would also be good.
*Frequency needs to be able to easily vary from a few Hz to tens of kiloHz or MegaHz
*Needs to display and select key information e.g. frequency, offset voltage, amplitude etc.
*Voltage offset TBD
*Amplitude adjustment
camerontbelt
