After disable BOD in Arduino code, I got much better results:
I used to need 1000 uF capacity, now 100 uF can power Atmega88V for few minutes.
A project log for NodeLP - Low power solution for DIY Sensor
NodeLP is designed for low power sensor node.Use it with any board such as Arduino, ESP8266, CC3200, CC2541 and other WiFi, BLE dev boards.
