Flashing it!
04/27/2017 at 18:08 • 0 commentsStep 1: Open Vivado Hardware Manager (and yes this is not Impact!)
Step 2: Click on Auto Connect Icon
Step 3: Right click on xc7a200, select "Add Configuration Memory Device"
Step 4: Select Spansion, 256, part: s25fl256xxxxxxxxxxxx0
Step 5: Select MCS file to flash, click OK
and wait 3 minutes :)
set_property PROGRAM.ADDRESS_RANGE {use_file} [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.FILES [list "B:/book/retro/mega65r1-20170417.mcs" ] [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0]]
set_property PROGRAM.UNUSED_PIN_TERMINATION {pull-none} [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.BLANK_CHECK 0 [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.ERASE 1 [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.CFG_PROGRAM 1 [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.VERIFY 1 [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
set_property PROGRAM.CHECKSUM 0 [ get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
startgroup
if {![string equal [get_property PROGRAM.HW_CFGMEM_TYPE [lindex [get_hw_devices] 0]] [get_property MEM_TYPE [get_property CFGMEM_PART [get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]]]] } { create_hw_bitstream -hw_device [lindex [get_hw_devices] 0] [get_property PROGRAM.HW_CFGMEM_BITFILE [ lindex [get_hw_devices] 0]]; program_hw_devices [lindex [get_hw_devices] 0]; };
INFO: [Labtools 27-3164] End of startup status: HIGH
program_hw_cfgmem -hw_cfgmem [get_property PROGRAM.HW_CFGMEM [lindex [get_hw_devices] 0 ]]
Mfg ID : 1 Memory Type : 2 Memory Capacity : 19 Device ID 1 : 0 Device ID 2 : 0
Performing Erase Operation...
Erase Operation successful.
Performing Program and Verify Operations...
Program/Verify Operation successful.
INFO: [Labtoolstcl 44-377] Flash programming completed successfully
program_hw_cfgmem: Time (s): cpu = 00:00:04 ; elapsed = 00:03:37 . Memory (MB): peak = 967.859 ; gain = 12.652
endgroup
Micro Python, here it comes.. again
04/26/2017 at 18:37 • 1 comment![]()
This is just a demo of very old micropython port for MicroBlaze, it is running on MEGA65 PCB rev 1 board with 1Mbyte RAM mapped as system memory.
Mouse programmed SoC on MEGA65, big picture in Vivado IPI.
C65 is alive... again )
04/17/2017 at 17:39 • 2 comments![]()
Back home from reVISION, trying out latest bit stream from MEGA65 team, and here we are up and running. Need find a keyboard now !!
VGA here it comes...
04/12/2017 at 19:25 • 0 commentsReady for testing...
Why is the image on the Display so dimmed? Well what would you expect if you tie BLANK input of VIDEO DAC to static value?
Found and fixed, much better now. The image on Display is actually pretty sharp, the handy camera snapshot is not the best.
POWER OK, No SMOKE!
04/12/2017 at 13:18 • 0 comments![]()
Close timing, the board is alive, LED's are working, FPGA is booting from SPI Flash. Now the fun can begin.
Waiting for PCB...
04/11/2017 at 14:11 • 0 comments![]()
Excited the PCB should arrive tomorrow before 0900 !
A fresh new Commodore since what year? ;)
reVISION here comes Xilinx FPGA...
04/07/2017 at 09:18 • 0 commentsWe submitted the files to Brandner PCB only about 57 minutes after the official urgent order deadline:
This is how it looks. PCB is in production, expect delivery from fab next tuesday, so delivery on 3rd working day from day of order. Ah yes we have to produce it then on Wednesday and ship on Thursday latest to reach the party in time..
And yes we did rush so much to be ready for reVISION party 2017 ...
Funny is that reVISION is also Xilinx new brand name, I happened to be at reVISON Summit 2017 in Nürnberg and was captured there next to an cobot:
I guess the reVISION in Saarbrücken would be fun too. Well if not me than the MEGA65 PCB should get there this year.
2 hours for PCB deadline
04/07/2017 at 05:38 • 0 commentstime is running up:
We had to make some executive decisions, as we did run out of FPGA IO pins, one the of 50 pin IDC headers for user extension was swapped in favor to 3 PMOD connectors.
PCB Progress
04/04/2017 at 07:23 • 0 comments![]()
All connectors placed, PCB outline fixed also. Routing left.
Youtube video link, interview in german
04/17/2016 at 19:04 • 0 commentsPublished on 8 Apr 2016
Das Projekt MEGA65 des Museum for Electronic Games & Art will den nie erschienenen Commodore C65 auf den Markt bringen. Detlef erzählt auch im Retroblah-Interview was zum letzten großen 8Bit-Rechner und den aktuellen Stand des Projekts.
Antti Lukats
